查看: 4491|回复: 5
MATS安装出错最后一步直接报错
发表于 2020-9-7 22:47:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 江苏宿迁 来自 江苏宿迁
cs@ubuntu:~/MATS-367.38.1$ sudo ./install_module.sh -i
make:进入目录'/home/cs/MATS-367.38.1/driver'
make -C /lib/modules/4.4.0-31-generic/build M=/home/cs/MATS-367.38.1/driver clean
make[1]: 正在进入目录 `/usr/src/linux-headers-4.4.0-31-generic'
make[1]:正在离开目录 `/usr/src/linux-headers-4.4.0-31-generic'
make:离开目录“/home/cs/MATS-367.38.1/driver”
make -C /lib/modules/4.4.0-31-generic/build M=/home/cs/MATS-367.38.1/driver modules
  CC [M]  /home/cs/MATS-367.38.1/driver/mods_krnl.o
  CC [M]  /home/cs/MATS-367.38.1/driver/mods_mem.o
  CC [M]  /home/cs/MATS-367.38.1/driver/mods_irq.o
  CC [M]  /home/cs/MATS-367.38.1/driver/mods_pci.o
  CC [M]  /home/cs/MATS-367.38.1/driver/mods_acpi.o
  CC [M]  /home/cs/MATS-367.38.1/driver/mods_debugfs.o
  LD [M]  /home/cs/MATS-367.38.1/driver/mods.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /home/cs/MATS-367.38.1/driver/mods.mod.o
  LD [M]  /home/cs/MATS-367.38.1/driver/mods.ko
make -C /lib/modules/4.4.0-31-generic/build M=/home/cs/MATS-367.38.1/driver modules_install
  INSTALL /home/cs/MATS-367.38.1/driver/mods.ko
At main.c:222:
- SSL error:02001002:system library:fopen:No such file or directory: bss_file.c:169
- SSL error:2006D080:BIO routines:BIO_new_file:no such file: bss_file.c:172
sign-file: certs/signing_key.pem: No such file or directory
  DEPMOD  4.4.0-31-generic
depmod: WARNING: -e needs -E or -F
To load the mods module on boot, add it to /etc/modules
cs@ubuntu:~/MATS-367.38.1$   ./check_config.sh
Checking OS... Linux - OK
Checking kernel version... 4.4.0 - WARNING - unrecognized kernel version
Checking architecture... x86_64 - OK
Checking libc version... 2.19 - OK
Checking MODS kernel module... 3.66 - OK
Checking conflicting kernel modules... none - OK
Checking console blank inverval... 600 - -e WARNING - please disable console blanking to avoid stability issues, run as root: # echo -ne '\033[9;0]\033[14;0]' > /dev/console
Looking for NVIDIA GPUs... ERROR - no NVIDIA GPUs found
cs@ubuntu:~/MATS-367.38.1$ ./install_module.sh -r
-e The install_module.sh script must be run with root privileges
以上是问题出处最后一步安装出现严重错误
发表于 2020-9-8 10:13:15 来自迅维网APP | 只看该作者 来自: 江苏 来自 江苏
谁来帮帮我
整整4天一直研究这个
发表于 2020-9-9 15:26:50 | 只看该作者 来自: 江苏 来自 江苏
./install_module.sh -r 这个命令不用运行,是卸载驱动模块的。可以直接运行测试命令
请教U盘DOS版367.38.1这个版本在双显卡笔记本上怎么用  详情 回复 发表于 2020-10-13 22:57
发表于 2020-9-9 15:39:10 | 只看该作者 来自: 江苏 来自 江苏
三个步骤:
         1,sudo ./install_module.sh -i    (安装模块,不是live系统运行一次就可以了,以后装载一下就可以了)
         2, ./check_config.sh                    (检擦运行条件是否满足,像你的找不到显卡,软件是只支持部分N卡)
         3,第二步没什么问题这里就可以运行测试命令,测试显卡或者显存。
OK谢谢你了伙计  详情 回复 发表于 2020-9-9 19:13
发表于 2020-9-9 19:13:11 | 只看该作者 来自: 江苏宿迁 来自 江苏宿迁
zhuaiwei7531 发表于 2020-9-9 15:39
三个步骤:
         1,sudo ./install_module.sh -i    (安装模块,不是live系统运行一次就可以了,以 ...
OK谢谢你了伙计
发表于 2020-10-13 22:57:21 | 只看该作者 来自: 天津红桥区 来自 天津红桥区
