查看: 2609|回复: 23
Acer Aspire M3970 CPU Core no voltage
发表于 2020-4-17 04:39:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 阿塞拜疆 来自 阿塞拜疆
Acer Aspire M3970
Motherboard code: IPISB-VR REV 1.01
PCH - HM67
There was a trigger when I examined the motherboard. but the voltage was cut off. maintenance on the motherboard in another service.
I examined the bios chip is broken. BIOS programmer - chip read error message. i bios chip replace.
there was a result. this time the motherboard started normally.
RAM +1.5v/ PCH +1.05v/ +1.8v - OK
CPU Core and GFX Core voltage - 0V
this time I started to examine the cpu circuit . CPU PWM - NCP6151
main voltage and enable signal normal. VRM_PWRGD - 0V (this is normal . because the circuit is not working)
this motherboard has 4 phase main coil. one coil GFX Core (intel hd graphic)
there is also an Buck MOSFET Drivers for core voltages (NCP5901)
later i realized that the Enable signal is too low ( +236mV) . this signal is normally +5V
DRVON - generates its signal in CPU PWM. I measured CPU PWM DRVON  signal
this signal is low due to another reason. i remove PR330. (2.2ohm)
I started the motherboard and the result is good. DRVON signal +5.0V OK
There is no problem in its  CPU PWM then.
I applied a method.
Buck MOSFET Drivers (NCP5901) - I cut the activ signals . Remove PR212 (0 ohm)
if no result, I would apply this method for the other PU15, PU16, PU17, PU18, PU19 and PU20(GFX)
I first applied this method PU14
Motherboard has started. DRVON enable signal is active (+5V). Motherboard gave beep signal 4 times. cpu on motherboard was broken
I wasn't sure the CPU was running because the motherboard was not working normally.
Replace CPU and worked
CPU Core +1.04V and GFX Core Voltage +0.4V
Replace NCP5901
This is signal DRVON Enable
This is signal CPU Core
Final Stage
Work BIOS
IPISB-VR REV 1.01 BIOS (4MB)
ipisb-vr rev1.01 HM67 4MB.zip
1.83 MB, 下载次数: 16, 下载积分: 下载分 -2 分, 下载 1 次
ipisb-vr rev1.01 HM67 4MB.rar
参与人数 5下载分 +15 +14 收起 理由
xiaowu2015 + 2 + 2 给愿意分享经验的人加分!
mjq8866 + 5 + 5 分享加分
DBJBW + 2 楼主总是在牛A与牛C之间徘徊
huiguorou + 5 + 5 精品文章
873808892 + 3 给愿意分享经验的人加分!
发表于 2020-4-19 08:55:08 | 只看该作者 来自: 广东深圳 来自 广东深圳
外国兄弟,支持支持
回复 支持 2 反对 0
发表于 2020-4-19 08:38:41 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
阿塞拜疆的坛友
发表于 2020-4-18 23:25:01 来自迅维网APP | 只看该作者 来自: 安徽池州 来自 安徽池州
雨天扔伞 发表于 2020-04-17 13:31
老外拿775老板子在练手??
不是775.应该是115x
发表于 2020-4-18 23:24:20 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
The signal will be cut off if you remove the pr212,then the pu14 would be disabled,can it generated the voltage?
发表于 2020-4-18 22:48:35 来自迅维网APP | 只看该作者 来自: 四川 来自 四川
来个翻译翻译
发表于 2020-4-18 19:39:41 | 只看该作者 来自: 山东潍坊 来自 山东潍坊
全是英文 果真是老外搞机
发表于 2020-4-18 19:38:24 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
国际友人吗?啥都没明白
发表于 2020-4-18 03:22:21 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
H55 发表于 2020-4-18 01:11
修得还行!where you from? Boy !
i live Azerbaijan
发表于 2020-4-18 01:31:33 | 只看该作者 来自: 台湾台北 来自 台湾台北
雨天扔伞 发表于 2020-4-17 13:31
老外拿775老板子在练手??
PCH-HM67      1151
补充内容 (2020-4-18 20:06):
錯 1155
发表于 2020-4-18 01:11:52 来自迅维网APP | 只看该作者 来自: 贵州 来自 贵州
发表于 2020-4-17 11:17:30 | 只看该作者 来自: 湖北 来自 湖北
外国兄弟,支持支持
发表于 2020-4-17 11:48:22 | 只看该作者 来自: 广东深圳 来自 广东深圳
NB ,一整篇我都是翻译着在看
发表于 2020-4-17 13:04:20 | 只看该作者 来自: 海南海口 来自 海南海口
搞英文看不懂哦。。
发表于 2020-4-17 13:31:07 | 只看该作者 来自: 山东济南 来自 山东济南
老外拿775老板子在练手??
不是775.应该是115x  详情 回复 发表于 2020-4-18 23:25
发表于 2020-4-17 13:42:39 | 只看该作者 来自: 江苏扬州 来自 江苏扬州
国外同行帖子水准挺高
发表于 2020-4-17 14:04:08 | 只看该作者 来自: 辽宁阜新 来自 辽宁阜新
The technology is really good, I hope to share more maintenance experience.
发表于 2020-4-17 17:17:45 | 只看该作者 来自: 广东茂名 来自 广东茂名
全是E文 果真是老外搞机
发表于 2020-4-19 03:42:48 | 只看该作者 来自: 阿塞拜疆 来自 阿塞拜疆
LGA 1155 Socket
发表于 2020-4-19 10:45:04 来自迅维网APP | 只看该作者 来自: 中国 来自 中国
全整因为牛逼。
