查看: 17555|回复: 12
[使用反馈]
笔记本点位图用Boardview打开的办法 Solution for Boardview opening error
发表于 2020-3-16 11:03:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东深圳 来自 广东深圳
鑫智造中,如果打不开tvw,brd等格式文件,是Boardview设置问题,看图
In Xinzhizhao, if the format files such as tvw and brd cannot be opened, it is a problem with Boardview settings. As shown in the figure:
笔记本点位图中Boardview 打开报错的解决办法:
The solution to the Boardview opening error in the laptop bitmap:
1、如果打开就报错提示缺少.netframwork,请自行百度搜索安装4.0以上.netframework。If an error is reported when the. netframework is opened, please search and install. netframework above 4.0 by yourself
     https://www.baidu.com/s?ie=utf8&oe=utf8&wd=%2Enetframework&tn=98010089_dg&ch=5
2、
如果Boardvier软件能打开但点位图打开报错,可以点击选项--图形,把GDI选中,拉到最右边。If the Boardvier software can be opened, but an error is reported when the bitmap is opened, you can click the option - Graph to select GDI and pull it to the far right.
      也可以下载群文件中 “boardviewer.zip” 覆盖到安装目录
3、
如果打开FZ格式点位图完全没反应,或提示选择用对应的程序打开,或者打开后是英文的boardviewer界面,可以这样设置。If there is no response when opening the FZ format bitmap, or you are prompted to choose to open it with the corresponding program, you can set it as follows
4、↓如果出现这个错误提示。If this error prompt appears
     请到C:\Program Files (x86)\XinZhiZao\bin\BoardViewer,以管理员权限运行BoardViewer.exe,按图设置。Please go to C:  Program Files (x86)  XinZhiZao  bin  BoardViewer, Run BoardViewer.exe with administrator privileges, and set as shown.
        如果还是不行,请自行搜索C++组件并安装:Microsoft Visual C++ 2015 Redistributable (x64),If it still doesn't work, please search for C++components and install them yourself: Microsoft Visual C++2015 Redistributable (x64)
5、如果提示数据载入错误,说明这个不兼容,要用专用点位图软件才可以打开。If a data loading error is prompted, it indicates that this is incompatible. It can only be opened with a special bitmap software
6、如果出现这个错误提示 If this error prompt appears
  请下载附件 BoardViewer.zip (468.1 KB, 下载次数: 796) ,解压后,找到C:\Program Files (x86)\XinZhiZao\bin\BoardViewer文件夹里面的BoardViewer.exe,替换BoardViewer.exe
Please download the attachment, unzip it, find BoardViewer.exe in C:  Program Files (x86)  XinZhiZao  bin  BoardViewer folder, and replace BoardViewer.exe
如果仍然解决不了,可以把C:\Program Files (x86)\XinZhiZao 文件夹改个名If the problem still cannot be solved, change the name of the C:  Program Files (x86)  XinZhiZao folder
如果还是有问题可以安装todesk或向日葵,联系鑫智造客服微信:18823306625远程协助解决
If you still have any questions, you can contact us:whatsapp +8618823306625
发表于 2020-4-2 17:25:53 | 只看该作者 来自: 江苏徐州 来自 江苏徐州
我的也是经常报错
回复 支持 0 反对 1
发表于 2020-3-18 13:36:34 | 只看该作者 来自: 福建泉州 来自 福建泉州
问哈boardviewer 启动报0xc000007b 怎么解决
4.0以上.netframework已装 百度无果 不想装系统  详情 回复 发表于 2020-4-15 10:38
没见过这个报错  发表于 2020-4-13 09:25
发表于 2020-4-15 10:38:42 | 只看该作者 来自: 福建泉州 来自 福建泉州
百度无果  不想装系统
解决了吗,我也是一样的问题  详情 回复 发表于 2020-6-3 20:28
发表于 2020-6-3 20:28:11 | 只看该作者 来自: 亚太地区 来自 亚太地区
百度无果  不想装系统
解决了吗,我也是一样的问题
发表于 2020-6-4 11:54:01 | 只看该作者 来自: 福建泉州 来自 福建泉州
没解决 好像是说dll文件有问题
不整了 等需要时  换个系统装
发表于 2020-7-27 09:58:06 来自迅维网APP | 只看该作者 来自: 河南南阳 来自 河南南阳
.netframework可以在系统高级设置里勾选会自动安装,不用百度,百度还容易下一大堆病毒,例如改主页什么的
已经装好的系统,怎么勾选?  详情 回复 发表于 2020-9-16 10:24
发表于 2020-9-16 10:24:11 | 只看该作者 来自: 广东深圳 来自 广东深圳
已经装好的系统,怎么勾选?
发表于 2021-7-12 13:55:21 | 只看该作者 来自: 广东江门 来自 广东江门
BoardViewer打开提示应用程序正常初始化(0xc0000135)失败,如何解决
可能不支持xp吧。这个是第三方软件,鑫智造只是调用,具体打不开的原因未知。  详情 回复 发表于 2021-12-28 17:01
发表于 2021-12-28 17:01:40 | 只看该作者 来自: 广东深圳 来自 广东深圳
发表于 2023-2-27 10:32:45 | 只看该作者 来自: 广东深圳 来自 广东深圳
BoardViewer各版本下载
BoardViewer 1.1.4.0.zip
1.59 MB, 下载次数: 18
BoardViewer 1.2.0.0.zip
1.11 MB, 下载次数: 5
BoardViewer 2.0.1.8 理论界汉化.zip
2.31 MB, 下载次数: 20
BoardViewer 2.0.1.8 玲珑心汉化.zip
2.38 MB, 下载次数: 20
BoardViewer 2.0.1.9 beta 玲珑心汉化.zip
1.4 MB, 下载次数: 53
BoardViewer 2.0.1.9 beta.zip
1.4 MB, 下载次数: 25
发表于 2023-3-16 01:16:42 | 只看该作者 来自: 云南 来自 云南
BoardViewer各版本下载
