查看: 2902|回复: 0
[已解决]
HP All-in-One - 20-c020il BIOS提取
发表于 2019-12-16 15:49:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 印度 来自 印度
HP All-in-One-20-c020il BIOS extraction
The HP All-in-One-20-c020il has a slow startup problem.
I want to write a new BIOS file.
I have the serial number and download the IT BIOS file from HP sp98347.EXE
I extracted it via WINRAR.
I have 081BAF48.EXE
But does not work in WIN7 32-bit,
I still use 7ZIP.
After i solved the problem
I found that HPWinGUI.exe was not downloaded, but after finishing downloading AMIUCP.EXE and extracting the files, all were written and resolved in one system.
Keep in mind that new deleted files are sometimes only included in the main BIOS file.
Older versions have EC BIOS and master file insertion capabilities.
HP一体机-20-c020il BIOS提取
HP All-in-One-20-c020il存在启动缓慢的问题。
我想写一个新的BIOS文件。
我有序列号并从HP sp98347.EXE下载IT BIOS文件
我是通过WINRAR提取的
我有081BAF48.EXE
但在WIN7 32位中不起作用
我还是用7号拉链
在我解决问题之后
我发现没有下载HPWinGUI.exe,但在下载完AMIUCP.exe并提取文件后,所有文件都在一个系统中写入和解析。
请记住,新删除的文件有时只包含在主BIOS文件中。
旧版本具有EC BIOS和主文件插入功能。
