查看: 2120|回复: 8
[显卡维修]
盈通9500 128m ddr帮忙看下是不是显存的问题,是哪个显存的问题?
发表于 2009-7-14 18:15:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南漯河 来自 河南漯河
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID 0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDB0 24 25 26 27 28 29 30 31
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID 0VB023
[3  ] RW page (GUI)                                       : FAIL
    Error ID 0VB025
[4  ] RW channel (GUI)                                    : FAIL
    Error ID 0VB028
[5  ] Data mask                                           : FAIL
    Error ID 0VB006
[6  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID 0VC006
[7  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID 0VC018
[8  ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID 0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.8 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.8 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.8 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.8 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.8 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.8 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.8 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.8 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.8 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.8 not found
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.8 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.8 not found
[9  ] Line slopes/dir/P/solid                             : FAIL
    Error ID 0TR010
     error : R051A.9 not found
     error : R052A.9 not found
     error : R053A.9 not found
     error : R055A.9 not found
     error : R061A.9 not found
     error : R062A.9 not found
     error : R063A.9 not found
     error : R065A.9 not found
     error : R071A.9 not found
     error : R072A.9 not found
     error : R073A.9 not found
     error : R075A.9 not found
Failure detected.
发表于 2009-7-14 18:29:25 | 只看该作者 来自: 云南曲靖 来自 云南曲靖
看看是不是GPU空焊了,,,这种一般不会有问题把,,
发表于 2009-7-14 18:44:27 | 只看该作者 来自: 广西南宁 来自 广西南宁
把SU2换掉可能就好了
发表于 2009-7-14 20:25:01 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
SU2   0---7 16--23
U2     8--15  24---31
最好测一下U2的控制线
发表于 2009-7-14 23:09:17 | 只看该作者 来自: 江苏苏州 来自 江苏苏州
如果 楼主的 显卡不是花的很厉害  就换u2
否则检u2测控制线
发表于 2009-7-20 13:25:43 | 只看该作者 来自: 河南漯河 来自 河南漯河
谢谢楼上的各位,师傅不知道把显卡放哪了,怎么处理了,所以没办法给各位回复了。
发表于 2009-7-21 11:52:35 | 只看该作者 来自: 广东广州 来自 广东广州
一个显存坏了,
发表于 2009-7-21 12:19:33 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
不要那么肯定就是一个显存的事。。具体哪个得人工测试。
你是根据软件的测试结果得知的吧。。
哪个显存?还请指出这样才可以帮到楼主嘛。。
发表于 2010-1-8 22:03:22 | 只看该作者 来自: 湖北武汉 来自 湖北武汉
我今天修了两块9500 128的 显卡 用软件测的和你的一样 把B区第二个换了 两个都好了  就是B区第二个显存坏了 也就是你图上的SU1
