- 积分
- 11031
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-2-25
- 精华
来自 2#
发表于 2019-9-17 09:11:18
只看该作者
来自: 广东深圳 来自 广东深圳
很好的分享和研究,不过这个标题有点大了,具体看,原因在于你自己对时序的一点小小误解.
以上观点是错误的!
由于没有6367的手册,参考6364吧,INTEL都一样
ISL6364 based VR has 4 periods during soft-start, as shown in
Figure 16. After VCC, EN_VTT and EN_PWR reach their POR/enable
thresholds, the controller will have a fixed delay period tD1. After this
delay period, the VR will begin first soft-start ramp until the output
voltage reaches VBOOT voltage at a fixed slew rate, quarter of setVID
FAST rate as in Table 6. Then, the controller will regulate the VR
voltage at VBOOT for another period tD3 until SVID sends a new VID
command. If the VID code is valid, ISL6364 will initiate the second
soft-start ramp at a slew rate, set by setVID FAST or SLOW
command in Table 6, until the voltage reaches the new VID voltage.
The soft-start time is the sum of the 4 periods
很明确的显示,芯片只需要软启动到VBOOT值,就可以发出PG。并不需要SVID
有些厂家会把VBOOT设置为0,所以需要SVID才有有CPU电压,才有PG
而另外的厂家会把VBOOT设置为1.1-1.2V,所以不需要SVID,就可以有PG
更多的学习,欢迎参加迅维培训!我qq191686994
想知道自己CPU的真实电压,可以去intel官网找,千万不要被预设的VBOOT电压迷惑哦
