查看: 3324|回复: 0
威刚S900 128G固态硬盘开卡失败求助
发表于 2019-8-6 22:11:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广西 来自 广西
主控 SF2241VB4,闪存ID查不到,我用的ID28026开卡到%80失败,不知道怎么搞下去了,请大神帮看下有什么问题
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Mon, 08/05/2019 @ 15:59:47
                  End Time: Mon, 08/05/2019 @ 16:00:50
             OverallResult: FAIL
                  ExitCode: (0x10090008:SF_GENESIS_FORMAT_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 3:0:0:0
                  argv[3]: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
                  argv[4]: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
                  argv[5]: 42
                  argv[6]: 42
                  argv[7]: LOG=/root/111/42_fedora14_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
                  Log File: /root/111/42_fedora14_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
                  Hostname: fedora14
           Host IP Address: 127.0.0.1
               Port Number: 1
                DeviceName: /dev/sg1
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 08/05/2019 15:59:47] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 3:0:0:0
                      argv[5]: 42
                      argv[6]: 42
[Mon 08/05/2019 15:59:47] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Mon 08/05/2019 15:59:52] - Issuing a discovery command for device: '3:0:0:0'
[Mon 08/05/2019 15:59:57] - Discovery command completed...
[Mon 08/05/2019 15:59:57] - Waiting 5 seconds for the system to settle...
[Mon 08/05/2019 16:00:02] - Device designation string '3:0:0:0' is mapped to node '/dev/sg1'
[Mon 08/05/2019 16:00:02] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
      Configuration File = /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
              Serial No. = 42
         World Wide Name = 42
[Mon 08/05/2019 16:00:03] - Successfully received the IDENTIFY data from the drive...
[Mon 08/05/2019 16:00:03] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Mon 08/05/2019 16:00:03] - Successfully opened the package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Mon 08/05/2019 16:00:03] - file  /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig Loaded successfully
[Mon 08/05/2019 16:00:03] - Warning:  Unable to query diagnostics information to perform power management settings check
[Mon 08/05/2019 16:00:03] - B01 Power Management configuration request detected
[Mon 08/05/2019 16:00:03] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
[Mon 08/05/2019 16:00:03] - Extracted Config_ID: 1 (28026) in DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
[Mon 08/05/2019 16:00:03] - Extracted SerialOutputControl: 0
[Mon 08/05/2019 16:00:03] - Searching for flashware image for configuration 28026
[Mon 08/05/2019 16:00:03] - Manifest found for configuration 28026
[Mon 08/05/2019 16:00:03] - Flashware image extracted: 28026_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_S_PP_R01298_s512.vic
[Mon 08/05/2019 16:00:03] - Searching for manufacturing image for configuration 28026
[Mon 08/05/2019 16:00:03] - Manufacturing image extracted: 28026_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_S_PP_R01298_s512.vic
[Mon 08/05/2019 16:00:03] - Proceeding in ROM mode, download feature 3...
[Mon 08/05/2019 16:00:03] - Successfully downloaded MFB to the drive...
[Mon 08/05/2019 16:00:03] - Waiting (5 sec) for the drive to settle...
[Mon 08/05/2019 16:00:08] - Successfully received the IDENTIFY data from the drive...
[Mon 08/05/2019 16:00:08] - Firmware revision reported to be: '582ABBM0'.  This indicates MFB download was successful.
[Mon 08/05/2019 16:00:08] - Successfully enabled SMART capabilities...
[Mon 08/05/2019 16:00:11] - Successfully issued a diagnostic unlock...
[Mon 08/05/2019 16:00:12] - Performing the flash test of block 0 (0x0000)...
[Mon 08/05/2019 16:00:15] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 1    | 0x0003 | N1,N3                                      | WARNING |
| 0    | 2    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 2    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 3    | 0x0002 | N3                                         | WARNING |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 16
      No. Passed without warnings: 0
[Mon 08/05/2019 16:00:15] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 34953 (0x8889)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Mon 08/05/2019 16:00:50] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Mon 08/05/2019 16:00:50] - End of Genesis manufacturing log.
[Mon 08/05/2019 16:00:50] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Mon, 08/05/2019 @ 15:59:47 </Start_Time>
        <End_Time> Mon, 08/05/2019 @ 16:00:50 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090008:SF_GENESIS_FORMAT_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 3:0:0:0
                  argv[5]: 42
                  argv[6]: 42
        </Input_Parameters>
        <Log_File> /root/111/42_fedora14_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
        <Hostname> fedora14 </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 1 </Port_Number>
        <Device_Name> /dev/sg1 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Mon 08/05/2019 16:00:50] - Overall Result for Device: /dev/sg1 ****** FAIL ******
