查看: 2312|回复: 7
[显卡维修]
两块9600花屏
发表于 2009-7-5 00:33:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东广州 来自 广东广州
新手,朋友有2块9600花了,下了论坛的ATI.EXE测试了下,看不懂结果,把结果贴上来请师傅们帮忙看看,谢谢了.
1.BGA显存的9600
TEST RESULT SUMMARY:
RV350/M10 (0x4151) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA1 12 26
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
    failing bit : MDA1 0 1 2 3 4 5 6 7 ...
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDA1 0 1 2 3 4 5 6 7 ...
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : PASS
[14 ] HOST_DATA/<f,b>/M2L                                 : PASS
[15 ] Line slopes/dir/P/solid                             : PASS
Failure detected.
2.TSOP的9600
RV360/M11 (0x4152) detected.
128M video memory.
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    failing bit : MDA0 48
    Error ID G0VB023
    failing bit : MDA0 16 17 18 19 20 21 22 23 ...
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VB006
    failing bit : MDA0 16 18 20 22 25 56 58 59 ...
    Error ID G0VC006
    failing bit : MDA0 8 9 10 11 16 17 18 19 ...
    Error ID G0VC009
    failing bit : MDA0 6 7 8 10 11 16 18 19 ...
    Error ID G0VC018
    failing bit : MDA0 1 2 3 4 5 6 7 8 ...
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDA0 4 8 10 11
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
    failing bit : MDA0 4 6 8 9 10 11 33 37 ...
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
发表于 2009-7-5 03:10:18 | 只看该作者 来自: 广西桂林 来自 广西桂林
你得用R3MEMID来测试,你这个不对。看不懂了。
发表于 2009-7-5 07:40:53 | 只看该作者 来自: 河北沧州 来自 河北沧州
显存芯片有问题,不过你这显卡好像没必要修了,太老了
发表于 2009-7-5 14:48:07 | 只看该作者 来自: 上海徐汇区 来自 上海徐汇区
这我修得多了,你把主芯片弄到BGA上加焊绝对OK
发表于 2009-7-5 15:30:47 | 只看该作者 来自: 广东广州 来自 广东广州
一个说主芯片,一个说显存,该信谁的呢?
发表于 2009-7-5 17:41:22 | 只看该作者 来自: 辽宁沈阳 来自 辽宁沈阳
BGA的图片你可以先测一下最下面的那一颗显存是否空焊
发表于 2009-7-6 23:31:30 | 只看该作者 来自: 重庆 来自 重庆
看不懂,稳当点都做一下
发表于 2009-7-7 00:06:31 | 只看该作者 来自: 浙江杭州 来自 浙江杭州
自己换个程序再测一下。要不你就把每个数据线都打一下值吧。。。
不知道你的是大花还是小花。
