- »ý·Ö
- 5
- ÏÂÔØ·Ö
- ·Ö
- ÍþÍû
- µã
- Ô´´±Ò
- µã
- ÏÂÔØ
- ´Î
- ÉÏ´«
- ´Î
- ×¢²áʱ¼ä
- 2018-11-28
- ¾«»ª
15#
·¢±íÓÚ 2019-1-5 14:22:12
Ö»¿´¸Ã×÷Õß
À´×Ô£º ºÓÄϰ²Ñô À´×Ô ºÓÄϰ²Ñô
ÇëÎÊÂ¥Ö÷¸Ã»ú¶ÀÏÔÇý¶¯Ò»Ö±´ò²»ÉÏÊÇÔõô»ØÊ£¿
»Ö¸´³ö³§ÎÞЧ£¬¿ª»ú×Ô¶¯¼ÓÔØ¶ÀÏÔÇý¶¯¹ý³ÌÖÐÀ¶ÆÁ£¬¹Ø±Õ¶ÀÏÔºóÕý³££¬ÒÔÏÂΪdumpÈÕÖ¾
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\112718-17968-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 10586 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Machine Name:
Kernel base = 0xfffff802`4aa04000 PsLoadedModuleList = 0xfffff802`4ace2c70
Debug session time: Tue Nov 27 22:30:58.262 2018 (UTC + 8:00)
System Uptime: 0 days 0:03:01.194
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Cannot read PEB32 from WOW64 TEB32 0000851c - Win32 error 0n30
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, ffffe0002c486060, ffffd00070feb890, ffffe0002f0b2570}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_IRP ***
*** work. ***
*** Type referenced: nt!TRIAGE_9F_POWER ***
*** work. ***
*** Type referenced: nt!_POP_IRP_WORKER_ENTRY ***
*** work. ***
*** Type referenced: nt!_LIST_ENTRY ***
*** work. ***
*** work. ***
*** Type referenced: nt!_IO_STACK_LOCATION ***
*** work. ***
*** In order for this command to work pr |
