- 积分
- 493
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2011-11-22
- 精华
Dell 15 3558 IRIS HSW / BDW 14216-1 0.17a Do not trigger
Use n16v-gm-b1.
The laptop has 0.17a that cannot be triggered. I turned on the laptop and checked if the pu4503 (labeled as tps51225) schematic has tps51225c) is hot. I changed tps51225, but after heating again. After that I changed io npce285pa0dx but the same tps51225 heat.
I checked if the capacitor is shorted but not shorted.
3v and 5v capacitors, line filter check can be. No grounding
Please help me with the landlord
