查看: 11788|回复: 30
[OPPO手机维修]
OPPO全系列 亲测解账户锁 屏锁和开机定屏 内附有详细教程
发表于 2017-4-15 21:37:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 河南 来自 河南
型号                   高速下载地址
OPPO 1105        http://url88.cn/10cfdIW
                        http://pan.baidu.com/s/1nu7vTjF
OPPO 1100        http://pan.baidu.com/s/1dFzeXsX
OPPO 1107        http://pan.baidu.com/s/1bo9e9QJ
                        http://pan.baidu.com/s/1kVt590V
OPPO 3000        http://pan.baidu.com/s/1nu7yxmx
OPPO 3005        http://pan.baidu.com/s/1gfmPGt1
OPPO 3007        http://pan.baidu.com/s/1dEDHUz3
OPPO A11        http://pan.baidu.com/s/1jIzDivk
                       http://pan.baidu.com/s/1qYNfitI
OPPO 6607        http://pan.baidu.com/s/1c1OBF2K
                http://pan.baidu.com/s/1skSm8pR
OPPO A30        http://pan.baidu.com/s/1miz9hX2
                 http://pan.baidu.com/s/1qYNLcte
OPPO A31        http://pan.baidu.com/s/1i5kgni9
                http://pan.baidu.com/s/1o7GhHwQ
OPPO A31c        http://pan.baidu.com/s/1i5kgni9
                http://pan.baidu.com/s/1o82kHcQ
OPPO A31T        http://pan.baidu.com/s/1i5kgni9
                http://pan.baidu.com/s/1cszLW6
OPPO A31u        http://pan.baidu.com/s/1cvhF34
OPPO A33        http://pan.baidu.com/s/1c1Dg1zE
                http://pan.baidu.com/s/1nvfSfKP
OPPO A33T        http://pan.baidu.com/s/1miI6Bxe
OPPO A33m        http://pan.baidu.com/s/1dFkorYT
OPPO A37m        http://pan.baidu.com/s/1mhU0ZW0
                http://pan.baidu.com/s/1eSMdSWU
OPPO A53T        http://pan.baidu.com/s/1bpxP9XP
OPPO A53M        http://pan.baidu.com/s/1eSHwqqe
OPPO A53        http://pan.baidu.com/s/1skWsLfZ
                http://pan.baidu.com/s/1bOFN0y
OPPO A59S        http://pan.baidu.com/s/1hsr9OcW
                http://pan.baidu.com/s/1bIAmxo
OPPO A59M        http://pan.baidu.com/s/1pKUuUev
                http://pan.baidu.com/s/1kVuPsc3
OPPO N1T        http://pan.baidu.com/s/1gf21gnp
OPPO N1W        http://pan.baidu.com/s/1gf21gnp
OPPO N5110        http://pan.baidu.com/s/1hsOJLM8
OPPO N5117        http://pan.baidu.com/s/1nvmFTED
OPPO R2017        http://pan.baidu.com/s/1nv0TDXJ
OPPO R7S PLUS        http://pan.baidu.com/s/1mikDSAs
OPPO R7 Plus        http://pan.baidu.com/s/1pLNh0eR
OPPO R7t        http://pan.baidu.com/s/1kV7IC2V
OPPO R7S        http://pan.baidu.com/s/1gfxHZ83
OPPO R7                http://pan.baidu.com/s/1i4U7hNf
                http://pan.baidu.com/s/1cu1DN4
OPPO R7 Plusm        http://pan.baidu.com/s/1gfxHZ83
OPPO R8000        http://pan.baidu.com/s/1eSoqHn8
OPPO R8007        http://url88.cn/19EjHkg
                http://pan.baidu.com/s/1slnUpJZ
OPPO R8107        http://pan.baidu.com/s/1kUS1QT5
OPPO R811        http://pan.baidu.com/s/1slLeoX3
OPPO R813T        http://url88.cn/cluyrH
                http://pan.baidu.com/s/1i53dDpr
OPPO R815T        http://pan.baidu.com/s/1pLHe66J
OPPO R819T        http://pan.baidu.com/s/1qYIy4pA
OPPO R8200        http://pan.baidu.com/s/1i4RkaED
                http://pan.baidu.com/s/1bpeSBOb
OPPO R8205        http://pan.baidu.com/s/1ge7A2wr
OPPO R8207        http://url88.cn/1j6oaVA
                http://pan.baidu.com/s/1qXKPwao
OPPO R821T        http://pan.baidu.com/s/1eSxKfAy
OPPO R823T        http://pan.baidu.com/s/1pLvzTVH
OPPO R827T        http://pan.baidu.com/s/1qYmAxbe
OPPO R829T        http://pan.baidu.com/s/1dFEHgZZ
OPPO R830S        http://pan.baidu.com/s/1gf43F03
OPPO R831S        http://pan.baidu.com/s/1dE2V9O9
OPPO R831T        http://pan.baidu.com/s/1dE2V9O9
OPPO R833T        http://pan.baidu.com/s/1skR9EzV
OPPO R850        http://pan.baidu.com/s/1i5C7fUl
OPPO U701T        http://pan.baidu.com/s/1hsbvwaC
                http://pan.baidu.com/s/1slU6VgT
OPPO U705T        http://pan.baidu.com/s/1nuSwXN7
                http://pan.baidu.com/s/1gfssvIj
OPPO U705W        http://pan.baidu.com/s/1nuSwXN7
OPPO U707T        http://pan.baidu.com/s/1qXGMs00
OPPO X9000        http://pan.baidu.com/s/1dF5TAIP
                http://pan.baidu.com/s/1boK9NWF
OPPO X9070        http://pan.baidu.com/s/1c1PsnL2
                http://pan.baidu.com/s/1geXYSJh
OPPO X9077        http://pan.baidu.com/s/1pLTVd4f
                http://pan.baidu.com/s/1nvO9y45
OPPO X909        http://pan.baidu.com/s/1i4AUTO5
                http://pan.baidu.com/s/1eSMfTPS
OPPO X909T        http://pan.baidu.com/s/1hrFaaA4
OPPO R6007        http://pan.baidu.com/s/1i4LKrrv
OPPO A51KC        http://pan.baidu.com/s/1miQEc2k
OPPO A11        http://pan.baidu.com/s/1dFj9adN
OPPO A51        http://pan.baidu.com/s/1miQEc2k
OPPO R7T        http://pan.baidu.com/s/1gfxHZ83
OPPO U707T        http://pan.baidu.com/s/1jHQ1m7c
OPPO R9M        http://url88.cn/lNz231
                http://pan.baidu.com/s/1dEPn4m1
OPPO A59m        http://pan.baidu.com/s/1ge2QJ0R
OPPO T29        http://pan.baidu.com/s/1pLlpKKj
参与人数 8下载分 +19 收起 理由
ASDSTDS + 1 楼主总是在牛A与牛C之间徘徊
繁星满天 + 2 我只能用 逗B 两个字来表达我对你的崇拜之.
古典浪漫 + 2 楼主总是在牛A与牛C之间徘徊
轩辕思天 + 2 双击666+关注!
疯子.... + 2 双击666+关注!
非凡小色 + 6 对大神的敬仰如同滔滔江水连绵不绝,一发不.
2206807866 + 2 双击666+关注!
乐呵呵 + 2 双击666+关注!
发表于 2017-4-19 17:03:10 | 只看该作者 来自: 广东广州 来自 广东广州
这样公布来不是很好吧,极坏搞坏市场,不是同行的建议看不到!
回复 支持 1 反对 1
发表于 2017-4-17 14:54:49 | 只看该作者 来自: 江苏南京 来自 江苏南京
很是全面,加分鼓励。
回复 支持 1 反对 1
发表于 2017-4-16 09:21:36 | 只看该作者 来自: 广东东莞 来自 广东东莞
维修OPPO的肯定有用,赞一个
发表于 2017-4-15 21:40:59 | 只看该作者 来自: 广西贵港 来自 广西贵港
机型很齐全,方便查找。精神可嘉!
发表于 2017-4-15 21:47:59 | 只看该作者 来自: 广东东莞 来自 广东东莞
正好我用的就 是OPPO,下来试试
发表于 2017-4-16 03:08:12 | 只看该作者 来自: 广东广州 来自 广东广州
多谢楼主的无私分享啊
发表于 2017-4-16 09:14:02 | 只看该作者 来自: 江苏 来自 江苏
当前修oppo绝对能用上,赞一个加分
发表于 2017-4-16 10:51:06 | 只看该作者 来自: 浙江台州 来自 浙江台州
确定可以吗 会不会变砖
发表于 2017-4-17 09:51:52 | 只看该作者 来自: 湖北 来自 湖北
BL锁也能解吗?
发表于 2017-4-17 10:24:56 | 只看该作者 来自: 吉林长春 来自 吉林长春
发表于 2017-4-18 08:56:41 | 只看该作者 来自: 江苏徐州 来自 江苏徐州
好多资料啊谢谢分享
发表于 2017-4-18 09:36:21 | 只看该作者 来自: 广东广州 来自 广东广州
厉害蛮   都可以下载保存了
发表于 2017-4-18 14:15:19 | 只看该作者 来自: 陕西西安 来自 陕西西安
谢谢你的分享
发表于 2017-4-18 15:07:32 | 只看该作者 来自: 湖南 来自 湖南
感谢分享,以后用得着
发表于 2017-4-19 09:23:37 | 只看该作者 来自: 山东济南 来自 山东济南
可以解账号?
发表于 2017-4-19 11:58:48 | 只看该作者 来自: 广东清远 来自 广东清远
收藏收藏收藏收藏收藏收藏收藏收藏
发表于 2017-4-19 13:29:43 | 只看该作者 来自: 山西阳泉 来自 山西阳泉
好东西谢谢
发表于 2017-4-22 11:11:49 | 只看该作者 来自: 江西赣州 来自 江西赣州
关键是里边的刷机包是不是纯净的刷机包,里边有没有垃圾软件一大推,成为了XX软件的推广平台,就像某海论坛里边的刷机包,全是垃圾软件,真TMD鄙视!!!没有一个纯净的刷机包!!!
发表于 2017-4-23 12:33:35 | 只看该作者 来自: 河南郑州 来自 河南郑州
很好  也用不上。。。。
