- 积分
- 149
- 下载分
- 分
- 威望
- 点
- 原创币
- 点
- 下载
- 次
- 上传
- 次
- 注册时间
- 2008-10-7
- 精华
小影霸R9550一进系统就重启,dos下正常,用r3memid测第7项有错误,
[7 ] Byte swap macro+micro8x2 read : FAIL
Error ID 0VC018
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
其余均PASS,请大家帮我看看是什么地方问题,下面如何查?
结果如下:
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
[1 ] Fill : PASS
[2 ] Data line toggle (GUI) : PASS
[3 ] RW page (GUI) : PASS
[4 ] RW channel (GUI) : PASS
[5 ] Data mask : PASS
[6 ] Macro + Micro8x2 tiling read : PASS
Error ID 0VC018
[8 ] HOST_DATA/<f,b>/M2L : PASS
[9 ] Line slopes/dir/P/solid : PASS
[1 ] Fill : PASS
Error ID 0VC018
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : PASS
Error ID 0VC018
Failure detected. |
