查看: 1005|回复: 2
Acer aspire la-a621p
发表于 2016-11-25 21:36:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 印度 来自 印度
Acer aspire Z5WE3-Z5WT3 compal_la-a621p_r0.3 no disply
发表于 2016-11-25 21:55:47 | 只看该作者 来自: 广东深圳 来自 广东深圳
Because you said too simple it is difficult to judge accurately.
If maintenance personnel recommended according to the sequence detection.
If the user Suggestions to send.
Good luck to you!
发表于 2016-11-26 02:34:43 | 只看该作者 来自: 广东东莞 来自 广东东莞
Life is like a play, all by acting! Yes, each of us to play a role in, but is it really you? Is the real you? Remember! No matter to any time don't forget your beginner's mind, the most true to yourself, don't when the withering, to think of "no! Forget to play the"
