查看: 1864|回复: 1
[显卡维修]
用r6xmemid检查无错误,但进入系统后出现花屏,请高手帮分析下
发表于 2009-4-18 17:59:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 来自: 广东深圳 来自 广东深圳
使用r6xmemid进行检查,结果如下:
R6XMEMID version 1.02, (c) Copyright ATI Technologies Inc, 2002
Log file generation enabled to .\R6XMEMID.LOG ...
Extended logging enabled ...
Loading Checksum and Gui CRC data from RDF file 'C:\A\R6XMEMID.M9' ...
Checksum Data Done.
No GUI CRC Data loaded from RDF.
TEST RESULT SUMMARY:
Rage6 Y` detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Memory Interface Data Test                          : PASS
[2  ] Memory Interface Address Test                       : PASS
[3  ] Fill ALL memory then read                           : PASS
[4  ] Read-Modify-Write                                   : PASS
[5  ] Micro+Macro tiling read                             : PASS
[6  ] 32-bit Z tiling write                               : PASS
[7  ] Byte swap z32 read                                  : PASS
[8  ] Micro+Marco alignment write                         : PASS
[9  ] 16-bit Z alignment read                             : PASS
[10 ] Basic solid rectangles                              : PASS
[11 ] PM4 T3 Indirect buf                                 : SKIPPED
[12 ] Line slopes/dir/P/solid                             : PASS
[13 ] HOST_DATA/<f,b>/M2L                                 : PASS
[14 ] HOST_DATA/color                                     : PASS
No failures detected.
进入系统后出现部分花屏,刷新下或者切换下界面又好了,过一下又出现,运行3D画面很花甚至死机,显卡未超频,系统重新安装过,不知道是什么原因,望高人指点下。。。不胜感激!
发表于 2009-4-18 19:20:25 | 只看该作者 来自: 广东佛山 来自 广东佛山
电源电路或电容问题!
