[p=169, null, left][size=169px]目前家庭使用[p=169, null, left][size=169px]DZ[p=169, null, left][size=169px]系列的空气开关[p=169, null, left][size=169px](带漏电保护的小型断路器)[p=169, null, left][size=169px],[p=169, null, left][size=169px]常见的有以下型号[p=169, null, left][size=169px]/[p=169, null, left][size=169px]规格:[p=169, null, left][size=169px]C16[p=169, null, left][size=169px]、[p=169, null, left][size=169px] C25[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C32[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C40[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C60[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C80[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C100[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C120[p=169, null, left][size=169px]等规格[p=169, null, left][size=169px],其中[p=169, null, left][size=169px]C[p=169, null, left][size=169px]表示脱扣电流,即起跳电流,例如[p=169, null, left][size=169px]C32[p=169, null, left][size=169px]表示起跳电流为[p=169, null, left][size=169px]32[p=169, null, left][size=169px]安,一般安装[p=169, null, left][size=169px]6500W[p=169, null, left][size=169px]热水[p=169, null, left][size=169px]器要用[p=169, null, left][size=169px]C32[p=169, null, left][size=169px],[p=169, null, left][size=169px]安装[p=169, null, left][size=169px]7500W[p=169, null, left][size=169px]、[p=169, null, left][size=169px]8500W[p=169, null, left][size=169px]热水器要用[p=169, null, left][size=169px]C40[p=169, null, left][size=169px]的空开。[p=169, null, left][size=169px]工业上常见的型号有:[p=169, null, left][size=169px]动力电路用[p=169, null, left][size=169px]DW[p=169, null, left][size=169px]和[p=169, null, left][size=169px]DZ[p=169, null, left][size=169px]型分[p=169, null, left][size=169px]20[p=169, null, left][size=169px],[p=169, null, left][size=169px]32[p=169, null, left][size=169px],[p=169, null, left][size=169px]50[p=169, null, left][size=169px],[p=169, null, left][size=169px]63[p=169, null, left][size=169px],[p=169, null, left][size=169px]80[p=169, null, left][size=169px],[p=169, null, left][size=169px]100[p=169, null, left][size=169px],[p=169, null, left][size=169px]125[p=169, null, left][size=169px],[p=169, null, left][size=169px]160[p=169, null, left][size=169px],[p=169, null, left][size=169px]250[p=169, null, left][size=169px],[p=169, null, left][size=169px]400[p=169, null, left][size=169px],[p=169, null, left][size=169px]600[p=169, null, left][size=169px],[p=169, null, left][size=169px]800[p=169, null, left][size=169px],[p=169, null, left][size=169px]1000...([p=169, null, left][size=169px]单位[p=169, null, left][size=169px]A)[p=169, null, left][size=169px]目前家庭使用[p=169, null, left][size=169px]DZ[p=169, null, left][size=169px]系列的空气开关[p=169, null, left][size=169px](带漏电保护的小型断路器)[p=169, null, left][size=169px],[p=169, null, left][size=169px]常见的有以下型号[p=169, null, left][size=169px]/[p=169, null, left][size=169px]规格:[p=169, null, left][size=169px]C16[p=169, null, left][size=169px]、[p=169, null, left][size=169px] C25[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C32[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C40[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C60[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C80[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C100[p=169, null, left][size=169px]、[p=169, null, left][size=169px]C120[p=169, null, left][size=169px]等规格[p=169, null, left][size=169px],其中[p=169, null, left][size=169px]C[p=169, null, left][size=169px]表示脱扣电流,即起跳电流,例如[p=169, null, left][size=169px]C32[p=169, null, left][size=169px]表示起跳电流为[p=169, null, left][size=169px]32[p=169, null, left][size=169px]安,一般安装[p=169, null, left][size=169px]6500W[p=169, null, left][size=169px]热水[p=169, null, left][size=169px]器要用[p=169, null, left][size=169px]C32[p=169, null, left][size=169px],[p=169, null, left][size=169px]安装[p=169, null, left][size=169px]7500W[p=169, null, left][size=169px]、[p=169, null, left][size=169px]8500W[p=169, null, left][size=169px]热水器要用[p=169, null, left][size=169px]C40[p=169, null, left][size=169px]的空开。[p=169, null, left][size=169px]工业上常见的型号有:[p=169, null, left][size=169px]动力电路用[p=169, null, left][size=169px]DW[p=169, null, left][size=169px]和[p=169, null, left][size=169px]DZ[p=169, null, left][size=169px]型分[p=169, null, left][size=169px]20[p=169, null, left][size=169px],[p=169, null, left][size=169px]32[p=169, null, left][size=169px],[p=169, null, left][size=169px]50[p=169, null, left][size=169px],[p=169, null, left][size=169px]63[p=169, null, left][size=169px],[p=169, null, left][size=169px]80[p=169, null, left][size=169px],[p=169, null, left][size=169px]100[p=169, null, left][size=169px],[p=169, null, left][size=169px]125[p=169, null, left][size=169px],[p=169, null, left][size=169px]160[p=169, null, left][size=169px],[p=169, null, left][size=169px]250[p=169, null, left][size=169px],[p=169, null, left][size=169px]400[p=169, null, left][size=169px],[p=169, null, left][size=169px]600[p=169, null, left][size=169px],[p=169, null, left][size=169px]800[p=169, null, left][size=169px],[p=169, null, left][size=169px]1000...([p=169, null, left][size=169px]单位[p=169, null, left][size=169px]A)
家用空气开关型号选择:
空气开关在家庭供电中作总电源保护开关或分支线保护开关用。当住宅线路或家用电器发生短路或过载时,它能自动跳闸,切断电源,从而有效的保护这些设备免受损坏或防止事故扩大;家庭一般用二极(即2P)空气开关作总电源保护,用单极(1P)作分支保护;空气开关的额定电流如果选择的偏小,则空气开关易频繁跳闸,引起不必要的停电,如选择过大,则达不到预期的保护效果,因此家装空气开关,正确选择额定容量电流大小很重要。一般小型空气开关规格主要以额定电流区分6A,10A,16A,20A,25A,32A,40A,50A,63A,80A,100A等;那么一般家庭如何选择或验算总负荷电流的总值呢?
1.首先计算各分支电流的值 ①纯电阻性负载,如灯泡,电热器等用注明功率直接除以电压即得,公式I=功率/220v;例如20w的灯泡,分支电流I=20W/220=0.09A。电风扇、电熨斗、电热毯、电热水器、电暖器、电饭锅、电炒锅、吸尘器、空调等为阻性负载。 ②感性负载,如荧光灯,电视机,洗衣机,等计算稍微复杂,要考虑消耗功率,具体计算还要考虑功率因数等,为便于估算,笔者给出一个简单的计算方法,即一般感性负载,根据其注明负载计算出来的功率在翻一倍即可,例如注明20W的日光灯的分支电流I=20W/220v=0.09A,翻倍为0.09A*2=0.18A(比精确计算值0.15A,多0.03A) 2.总负荷电流即为各分支电流之和;知道了分支电流和总电流,就可以选择分支空气开关及总闸空气开关、总保险丝,总电表以及各支路电线的规格,或者验算已设计的这些电气部件的规格是否符合安全要求; 3.为了确保安全可靠,电气部件的额定工作电流一般应大于2倍所需的最大负荷电流;此外,在设计、选择电气部件时,还要考虑到以后用电负荷增加的可能性,为以后需求留有余量
