标题: XFX 6800XT花屏,有新进展了!大家来看看(已修复) [打印本页]
作者: 环牛    时间: 2008-10-9 15:47
八片显存的
          U3 U4              U5 U6
U1  U2        GPU                  U7 U8
Tested from 0 MB to 256 MB.
    LANE     E_BANK0 ERRORS
FBA[31: 0]            9152
FBA[63:32]            9852
FBB[31: 0]            9392
FBB[63:32]        16819644
FBC[31: 0]            8920
FBC[63:32]            9644
FBD[31: 0]            9164
FBD[63:32]            9852
External Bank 0 Failing bits:
   A00 A01 A02 A03 A04 A05 A06 A07 A08 A09 A10 A11 A12 A13 A14 A15
   A16 A17 A18 A19 A20 A21 A22 A23 A24 A25 A26 A27 A28 A29 A30 A31
   A32 A33 A34 A35 A36 A37 A38 A39 A40 A41 A42 A43 A44 A45 A46 A47
   A48 A49 A50 A51 A52 A53 A54 A55 A56 A57 A58 A59 A60 A61 A62 A63
   B00 B01 B02 B03 B04 B05 B06 B07 B08 B09 B10 B11 B12 B13 B14 B15
   B16 B17 B18 B19 B20 B21 B22 B23 B24 B25 B26 B27 B28 B29 B30 B31
   B32 B33 B34 B35 B36 B37 B38 B39 B40 B41 B42 B43 B44 B45 B46 B47
   B48 B49 B50 B51 B52 B53 B54 B55 B56 B57 B58 B59 B60 B61 B62 B63
   C00 C01 C02 C03 C04 C05 C06 C07 C08 C09 C10 C11 C12 C13 C14 C15
   C16 C17 C18 C19 C20 C21 C22 C23 C24 C25 C26 C27 C28 C29 C30 C31
   C32 C33 C34 C35 C36 C37 C38 C39 C40 C41 C42 C43 C44 C45 C46 C47
   C48 C49 C50 C51 C52 C53 C54 C55 C56 C57 C58 C59 C60 C61 C62 C63
   D00 D01 D02 D03 D04 D05 D06 D07 D08 D09 D10 D11 D12 D13 D14 D15
   D16 D17 D18 D19 D20 D21 D22 D23 D24 D25 D26 D27 D28 D29 D30 D31
   D32 D33 D34 D35 D36 D37 D38 D39 D40 D41 D42 D43 D44 D45 D46 D47
   D48 D49 D50 D51 D52 D53 D54 D55 D56 D57 D58 D59 D60 D61 D62 D63
Read    Error Count: 0
Write   Error Count: 16885620
Unknown Error Count: 0
ADDRESS  EXPECTED  ACTUAL  REREAD1  REREAD2  REREAD3  TYPE  P L E I ROW  COL BO
0ed4c63c 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 009 3
0ed4c638 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 009 2
0ed4c634 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 009 1
0ed4c630 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 009 0
0ed4c61c 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 008 3
0ed4c618 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 008 2
0ed4c614 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 008 1
0ed4c610 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0ed4 008 0
0b957efc 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 1 0b95 07f 3
0b957ef8 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 1 0b95 07f 2
0b957ef4 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 1 0b95 07f 1
0b957ef0 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 1 0b95 07f 0
[ 本帖最后由 环牛 于 2008-10-16 14:27 编辑 ]
作者: 郭郭有志    时间: 2008-10-9 17:14
每个数据位都出错,无一漏网。
作者: 环牛    时间: 2008-10-9 17:33
这个是用坛子里的MATS全集里的MATS6测试得到的结果。换坛子里的MATS4.78测试结果如下:
   LANE    EB0 READ ERR EB0 WRT ERR  UNKNOWN ERR
FBA[31: 0]           0            0            0
FBA[63:32]           0            0            0
FBB[31: 0]           0            0            0
FBB[63:32]           0     16817216            0
FBC[31: 0]           0            0            0
FBC[63:32]           0            0            0
FBD[31: 0]           0            0            0
FBD[63:32]           0            0            0
   B55
Read    Error Count: 0
Write   Error Count: 16817216
BIT  FRONT WRITE  FRONT READ  UNKNOWN
B55    16817216           0           0
ADDRESS  EXPECTED  ACTUAL  REREAD1  REREAD2  FAILBITS TYPE  P L E I ROW  COL BO
0f7df3bc 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0f7d 065 3
0f7df3b8 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0f7d 065 2
0f7df3b4 00000000 00800000 00800000 00800000 00800000 WRITE B 1 0 3 0f7d 065 1
根据上面的测试结果看来,MATS4.78的测试应该准确些,因为这个卡只是小花,还是看的清的。从4.78的结果分析,是不是可以得出这样一个结论:该卡的B组的第二片显存有问题。根据该卡的显存排列。应该是U5或者U6有问题。是不是这样,请高手帮忙分析一下。
                 U3U4                      U5U6
U1 U2            GPU                          U7U8
[ 本帖最后由 环牛 于 2008-10-15 13:11 编辑 ]
作者: 环牛    时间: 2008-10-15 13:26
就是这个!!!!
作者: 环牛    时间: 2008-10-15 17:49
大家过来帮忙看看啊!!!
作者: 郭郭有志    时间: 2008-10-15 18:31
贴一张背面的图片。看有没有与显存有关的小元件。
作者: 郭郭有志    时间: 2008-10-15 18:33
标题: 回复 #3 环牛 的帖子
你这分析很好!!
看来用错软件,会误导维修思路。
作者: 菜单蔡丹    时间: 2008-10-15 19:41
哇。好行进哟。啷个测哟?
作者: 环牛    时间: 2008-10-15 20:46
背面的图片
作者: 荣耀万里    时间: 2008-10-15 20:49
现在怎么样了?是显存问题吗?
作者: 树林林    时间: 2008-10-15 21:10
应该是U6,我估的!
作者: 环牛    时间: 2008-10-16 14:25
昨天很忙,没时间搞。今天再来。先发个显卡上标的显存编号:
                U18 U19
                                            U20 U21
U22 U23
                      GPU                 U16
                                             U17
补焊U20,U21。试机,故障排除。再无花屏。现正在烤机中。
测试结果:
FBA[31: 0]           0            0            0
FBA[63:32]           0            0            0
FBB[31: 0]           0            0            0
FBB[63:32]           0            0            0
FBC[31: 0]           0            0            0
FBC[63:32]           0            0            0
FBD[31: 0]           0            0            0
FBD[63:32]           0            0            0
   None
Read    Error Count: 0
Write   Error Count: 0
No errors logged.
No errors logged.
[ 本帖最后由 环牛 于 2008-10-16 14:29 编辑 ]
作者: 主板水手    时间: 2008-10-16 18:39
u5   u6怎么会变成U20 U21啊???
作者: 环牛    时间: 2008-10-16 18:41
U5U6是我自己编的序号。U20U21是板子上的编号
作者: 爱她这是秘密    时间: 2008-10-16 19:50
高手如云,大家都很厉害啊
作者: 四维木    时间: 2008-10-16 20:22
补焊?加焊?BGA封装有补焊吗?怎么弄?
作者: 郭郭有志    时间: 2008-10-17 08:45
祝贺一下!
就是B55所在的U20,一个数据位虚焊。
应该与U21无关。
作者: 小小稀饭    时间: 2008-10-17 20:43
楼上能准确判断是U20,不是U21,看图纸的?我也有块这样的还不能判断是那个。。有的话能不能法上来给我看看,谢谢了,没的花也没事,有空我去一个个做做看,谢谢了。。
作者: 长治维修    时间: 2008-10-17 20:53
为什么不先用BGA加焊一下呢...也没有那么复杂的.我今天下午的6200一加焊就OK了...如果加焊不行,再测嘛.先简单再复杂嘛...
作者: 小小稀饭    时间: 2008-10-17 20:58
如果是BGA坏的话,加血又没用的楼,我都加热过了
作者: 环牛    时间: 2008-10-18 10:05
呵呵。没有工具的情况下不要轻易的加焊GPU,我就失败过N次了。好多花屏的卡,加焊GPU就点不亮了。不要看高手们说的很轻松,其实在你没有他们那些专业的设备的时候,加焊很难保证板子,GPU受热均匀。失败也就是注定的。我现在修显卡,不到万不得已的情况下,绝对不加焊GPU。
作者: johnnylu    时间: 2008-10-19 11:54
标题: 回复 #25 环牛 的帖子
呵呵 同感
至于你第一张图标的显存的顺序 我不认同 http://www.chinafix.com.cn/bbs/thread-71002-1-1.html
这个是我测试的结果
参照你的显卡  应该是 反过来的
也就是  D C B A 组
B55 错误 应该是在 U20上
作者: 环牛    时间: 2008-10-19 18:54
标题: 回复 #26 johnnylu 的帖子
是这样的。我第一张图,是我为了描述的方便自己编的号。是顺时针排的。这个卡的显存是逆时针排列的。
