Selected family ........................... CALYPSO
Model ..................................... Maxtor 6Y120P0
Firmware .................................. YAR41BW0
Serial .................................... Y3K0CGHE
Min. cylinder ............................. 1046
Max. cylinder ............................. 89697
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 38
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. Y3K0CGHE
Max LBA ................................... 240359842
Head number ............................... 3
Head map .................................. 3 4 5
SA head map ............................... 3 4 5
Model1 ............................... Maxtor 6Y126P3
Max LBA .............................. 240121728
Model2 ............................... Maxtor 6Y120P3
Model3 ...............................
Max LBA .............................. 0
Model4 ............................... Maxtor 6Y090P3
Max LBA .............................. 180154800
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV6i
Checking User data adaptives
Header .................................... CR0T`作者: 子宁 时间: 2008-10-2 03:37
Header1 ................................... MO
Header2 ................................... B0?
OverlayId ................................. 001A
ROM CRC ................................... Ok
Header2 ................................... B000
OverlayId ................................. 001B
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
Checking RZTbl
Checking P-List
Checking S.M.A.R.T.
[SMRT_T] .................................. Error
[SMRT_A] .................................. Error
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking FMTI
Id ........................................ 93
Header .................................... Ok
Checking [DISK/PW]
not found作者: 子宁 时间: 2008-10-2 03:37 标题: MT6Y的120G盘, SA测试报错 Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. Ok
Module 19 ................................. UBA 400 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/17
Module 1A ................................. UBA 401 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/17
Module 1B ................................. UBA 682 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/298
Module 1C ................................. UBA 421 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/39
Module 1D ................................. UBA 680 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/296
Module 1E ................................. Ok
Module 1F ................................. UBA 8 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89717/3/8
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. UBA 419 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/35
Module 24 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. UBA 402 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/18
Module 30 ................................. UBA 403 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/19
Module 32 ................................. Ok
Module 33 ................................. Ok
Module 34 ................................. UBA 426 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/42
Module 37 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. UBA 399 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/17
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. UBA 679 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/296
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. UBA 759 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/375
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. UBA 754 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/370
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6F ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. UBA 927 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89719/3/161
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. Ok
Module 79 ................................. Ok
Module 7A ................................. Ok
Module 7B ................................. UBA 929 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89719/3/161
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8C ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 90 ................................. Ok
Module 92 ................................. Ok
Module 93 ................................. Ok
Module 94 ................................. Ok
Module 96 ................................. Ok
Module 97 ................................. Ok
Module 98 ................................. Ok
Module 99 ................................. Ok
Module 9A ................................. Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E ................................. Ok
Module 9F ................................. Ok
Module A1 ................................. Ok
Module A2 ................................. Ok
Module A5 ................................. Ok
Module A6 ................................. Ok
Module A7 ................................. UBA 5924 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89732/3/164
Module A9 ................................. Ok
Module AA ................................. Ok作者: 子宁 时间: 2008-10-3 01:59
SA testing and recovery测试如下:
