PHP Debug
No. | File | Line | Code |
1 | forum.php | 57 | discuz_application->init() |
2 | source/class/discuz/discuz_application.php | 70 | discuz_application->_init_cron() |
3 | source/class/discuz/discuz_application.php | 553 | discuz_cron::run() |
4 | source/class/discuz/discuz_cron.php | 48 | include(%s) |
5 | source/include/cron/cron_member_optimize_daily.php | 13 | table_common_member->split(%d) |
6 | source/class/table/table_common_member.php | 365 | discuz_database::query(%s, Array, false, true) |
7 | source/class/discuz/discuz_database.php | 137 | db_driver_mysql->query(%s, false, true) |
8 | source/class/db/db_driver_mysql.php | 153 | db_driver_mysql->halt(%s, %d, %s) |
9 | source/class/db/db_driver_mysql.php | 224 | break() |
