标题: 在ST_MEM软件中回写ATA的指令 [打印本页] 作者: 钟弘林 时间: 2008-6-9 14:12 标题: 在ST_MEM软件中回写ATA的指令 Try this now, it SDLD supports. Malformed tracks, so long
Sozdash file with the extension. Cmd
inside it is this
should be.
In this example, the file name for example, can call as you want. Before this cook image of the file. Opens NEH-editor and cut off from the end of last FF (they are usually several rows). All that remained from the beginning - and it will overlay your image. Pre-check the image size, it must be a multiple of 512! The image put in a folder with ST-Mem, but not in a folder CMD (it only batch files).
When zalesh ST-Mem 'box in memory of those komandnikom, need to write it on pancakes, that is
T> c.
Fse It takes 15-20 minutes total-something.
Good luck!
