9550 128M显卡进入系统前蓝屏
工装
2009-12-4 19:30
9550 128M显卡进入系统前蓝屏
原来是花屏,换了U4和U8;
9550的测试结果,帮我看看还有哪里有毛病?
R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : PASS
[2 ] Data line toggle (GUI) : PASS
[3 ] RW page (GUI) : PASS
[4 ] RW channel (GUI) : PASS
[5 ] Data mask : PASS
[6 ] Macro + Micro8x2 tiling read : PASS
[7 ] Byte swap macro+micro8x2 read : FAIL
Error ID 0VC018
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[8 ] HOST_DATA/<f,b>/M2L : PASS
[9 ] Line slopes/dir/P/solid : PASS
Failure detected.
多多
2009-12-5 15:06
U3和U5很有可能是PCB问题
工装
2009-12-5 17:45
请问版主是PCB哪方面的问题?
显卡修好了
2009-12-5 22:28
现在的情况 看不出来花吧。。
把 ab区首位显存换了 再测试
