标题: 帮忙分析一个测试结果。铭瑄X800XL [打印本页]
作者: 华邦    时间: 2009-9-4 15:22
铭瑄X800XL白金版128M/256位
R3MEMID version 1.13, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
R430 A11 (0x554f) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : PASS
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
  1024 x  768 - 16 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDD0 60 61
[3  ] RW column (GUI)                                     : PASS
[4  ] RW page (GUI)                                       : PASS
[5  ] RW channel (GUI)                                    : PASS
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
[7  ] Macro + Micro8x2 tiling read                        : PASS
[8  ] Macro + Micro4x4 tiling write                       : PASS
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : PASS
[12 ] Macro+Micro4x4 alignment read                       : PASS
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST PASSED
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST PASSED
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST PASSED
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
Failure detected.
正面是  U1     U2
                          U4
                          U10
反面是 SU2     SU1
                           SU3
                            SU7
作者: 兄弟电脑电器    时间: 2009-9-4 15:49
好修呀
定下位呀
前几天有个大哥发了定位图
去找一下
作者: 显卡修好了    时间: 2009-9-4 16:40
好修呀
定下位呀
前几天有个大哥发了定位图
去找一下
兄弟电脑电器 发表于 2009-9-4 15:49
没记错的话应该是  x850的  不一样
楼主按图上的测量下排阻的  对地阻值
作者: 华邦    时间: 2009-9-5 16:08
3# 显卡修好了
感谢 大哥啊
我昨天自己拆排阻测的。就是这个排阻虚焊了。
十分感谢。显卡已修好了
作者: 星辰一怒    时间: 2009-9-6 11:03
看不懂测试结果啊,上哪能找到定位图?
作者: 多多    时间: 2009-9-6 12:40
看不懂测试结果啊,上哪能找到定位图?
星辰一怒 发表于 2009-9-6 11:03
你注册也有一年多了,这句话用这么说吗?
找不到就好好学吧!
