标题: SSD m2 PS5013-E13-31 (SP512gbp34A60M28) [打印本页]
作者: bygatti2012    时间: 2022-4-2 16:56
PS5013-E13-31 (SP512gbp34A60M28) good afternoon, help with the firmware and firmware program for this SSD m2 built on the PS5013-E13-31 controller is defined as 1megabyte
作者: bygatti2012    时间: 2022-4-2 18:17
PS5013-E13-31 (SP512gbp34A60M28) good afternoon, help with the firmware and the program searched everywhere but never found
作者: 海成科技1888    时间: 2022-4-2 20:53
啥
作者: bygatti2012    时间: 2022-4-2 22:37
我找不到此ssd的固件和程序当联系人关闭时,它进入rom模式并显示为1兆字节。帮助固件[backcolor=rgba(0, 0, 0, 0.04)]I can't find the firmware and program for this ssd when the contacts are closed, it enters rom mode and is displayed as 1 megabyte.Help with the firmware
作者: bygatti2012    时间: 2022-4-4 00:37
here's what the program shows
phison_e7_flash_id.txt
298 Bytes, 下载次数: 14, 下载积分: 下载分 -2 分, 下载 1 次
作者: 13861406000    时间: 2022-4-4 01:04
放弃吧。这个主控开卡需要治具的。
作者: bygatti2012    时间: 2022-4-4 17:36
I don 't understand you, what do I need to restore it ?????
作者: bygatti2012    时间: 2022-4-6 14:03
good morning someone can tell you how to flash it
作者: bygatti2012    时间: 2022-4-6 20:30
I ask you to help with the firmware for this ssd
作者: 13861406000    时间: 2022-4-6 20:56
It's means :No way!
作者: bygatti2012    时间: 2022-4-6 21:34
as I understand it, no one can help with the firmware for this ssd
