标题: 请问这是GPU坏还是显存坏.ati9700 mobility 64M [打印本页] 作者: 郑善洋 时间: 2009-7-18 11:28 标题: 请问这是GPU坏还是显存坏.ati9700 mobility 64M Rage6 NP detected.
64M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Memory Interface Data Test : PASS
[2 ] Memory Interface Address Test : PASS
[3 ] Fill ALL memory then read : FAIL
Error ID 0TB021
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA0 12 15 MDB0 12 15
