PHP Debug
No. | File | Line | Code |
1 | portal.php | 32 | require_once(%s) |
2 | source/module/portal/portal_view.php | 311 | include_once(%s) |
3 | data/template/5_diy_portal_view_34.tpl.php | 1 | hookscriptoutput(%s) |
4 | source/function/function_core.php | 1227 | hookscript(%s, %s) |
5 | source/function/function_core.php | 1190 | call_user_func(Array, Array) |
6 | plugin_xunwei_google->global_usernav_extra1(Array) | ||
7 | source/plugin/xunwei_google/xunwei_google.class.php | 22 | plugin_xunwei_google->getCityByIp(%s) |
8 | source/plugin/xunwei_google/xunwei_google.class.php | 49 | discuz_database::result_first(%s) |
9 | source/class/discuz/discuz_database.php | 118 | discuz_database::query(%s, Array, false, false) |
10 | source/class/discuz/discuz_database.php | 137 | db_driver_mysql->query(%s, false, false) |
11 | source/class/db/db_driver_mysql.php | 153 | db_driver_mysql->halt(%s, %d, %s) |
12 | source/class/db/db_driver_mysql.php | 224 | break() |
